Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
Meta Quest 3 Elite Strap
free standard delivery
£69.99
30 In Stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Designed for the Meta Quest 3 virtual reality headset
  • Includes a head strap for a secure fit
  • Made from a combination of fabric, plastic, and silicone for comfort and durability
  • Type: Controller Strap
Product codes
chevron icon
chevron icon
Play in comfort with this adjustable, ergonomic head strap that fits most head sizes with the quick turn of a dial. This Elite Strap upgrades your fit by taking pressure off your face for increased comfort and weight distribution. The soft, flexible silicone support cradles the back of your head, reducing fatigue. This genuine Meta Quest accessory easily installs on your Meta Quest 3 for a perfect and secure fit every time you play, create and explore in VR.
Ready for action
This compact, lightweight strap reduces facial pressure and evenly distributes weight for a more comfortable fit. It also has improved durability, building on the learnings from our earlier generations of Elite Strap.
Adjusts in seconds
A twist of the adjustment dial gives you a snug, precise fit around your head, so you can move confidently whether you're battling it out or getting your sweat on.
Longer immersion
A soft, flexible silicone support cradles the back of your head for the most comfortable and balanced fit for any experience.
Perfect alignment
This flexible top strap adjusts to keep your headset at a comfortable position over your eyes and further disperses weight.
Seamless compatibility
Works with the Meta Quest 3 Charging Dock for effortless headset and controller charging. Also fits in the Meta Quest 3 Carrying Case without having to be removed.
Genuine Meta Quest accessory
Built to work seamlessly with Meta Quest 3 and backed by a one year warranty, this official accessory has been tested for quality and durability – ensuring you get the best look, feel, compatibility and performance.
chevron icon
Product Description Meta Quest 3 - head strap for virtual reality headset
Product Type Head strap
Intended For Virtual reality headset
Package Content Head strap
Product Material Plastic, fabric, silicone
Dimensions (WxDxH) 16.45 cm x 24.02 cm x 10.15 cm
Weight 183 g
Colour White
Designed For Meta Quest 3
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£69.99
