ITEM | QTY | PRICE |
Canon 718 Black Toner
4 | £408.08 |
Dynamic Crystal Colour
Crystal clear, lifelike colour
Whether you're bingeing on a boxset or feasting on a blockbuster, you’ll see everything in crystal clear and lifelike colour. Dynamic Crystal Colour delivers rich and vibrant images in over one billion shades – 64 times more than conventional UHD TVs.
Airslim
A slim and sleek design
You don’t just want your TV to look good when it's on - you want it to blend into your room when it's off too. This TV has a slim design with a clean cable solution, so it will look stunning from any angle.
Crystal Processor 4K
Upgrade the picture and sound quality
Think of the processor as the brain of the TV, working in the background to improve the picture and sound quality. Simply relax and enjoy the content you love whilst the TV boosts the quality to 4K detail and adjusts the sound depending on what's playing. Streaming movies or watching live sport, you’ll feel part of the action.
Smart TV powered by Tizen
An abundance of apps and services to enjoy
With the best-selling Samsung Smart TV* you can dive into a huge collection of 4K films, TV shows and all your catch-up TV apps – including Netflix, Disney+, Apple TV, NOW TV and BT Sport apps** – all in one place. Not sure what to watch? Our easy-to-use Smart Hub platform gives you recommendations. (Subscriptions required)
Product Description | Samsung UE75CU8000K CU8000 Series - 75" LED-backlit LCD TV - Crystal UHD - 4K | Product Type | LED-backlit LCD TV - Crystal UHD - Smart TV | Diagonal Class | 75" | Colour | Black | Platform | Tizen OS | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Format | HDR10+ | HDR Technology | Hybrid Log-Gamma (HLG) | Frame Rate & Enhancement Technology | 50 Hz Refresh Rate, Motion Xcelerator | Video Interface | HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | LED backlight UHD dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-T2 | Internet Streaming Services | Samsung TV PLUS | Picture Enhancements | Mega Contrast, contrast enhancer, Dynamic Crystal Color, One Billion Colour | Speaker System | 2 channel | Platform | SmartThings | Intelligent Assistant | Google Assistant, Alexa, Bixby (not available for some languages and countries) | USB | 2 ports | Included Accessories | Samsung TM2360E remote control | Voltage | AC 220-240 V (50/60 Hz) | Energy Class | Class G | Power Consumption Operational | 139 Watt | Power Consumption Stand by | 0.5 Watt | Dimensions (WxDxH) - without stand | 167.67 cm x 2.66 cm x 96.03 cm | Weight | 31.4 kg |
General | |
Energy Class (HDR) | Class G |
Power Consumption (Max) | 255 Watt |
Power Consumption SDR (On mode) | 139 kWh/1000h |
Power Consumption HDR (On mode) | 224 kWh/1000h |
Series | CU8000 Series |
Model Year | 2023 |
HDR Capable | Yes |
Video Processor | Crystal 4K |
TV Tuner Presence | Yes |
Sensors | Eco Sensor |
Modes | Film Mode, Auto Game Mode, Auto Low Latency Mode (ALLM), Filmmaker Mode, HGIG Mode |
Design | 3 Bezel-less Design, Slim look, AirSlim design |
Dimensions | Without stand |
Width | 167.67 cm |
Depth | 2.66 cm |
Height | 96.03 cm |
Weight | 31.4 kg |
Enclosure Colour | Black |
Display | |
Display Menu Language | Multilingual |
Features | E-Manual, Wireless TV On, MBR Support, Brightness Detection, Samsung Health, Wireless Dex, Microsoft 365 Cloud, Auto Channel Search, Mobile camera support, Gaming Hub, SlimFit Cam support, Nifty Gateway, Universal Guide, Easy Setup, App Casting |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Stand Colour | Black |
Stand Features | Flat lift |
Flat Panel Mount Interface | 400 x 400 mm |
VESA Compatibility | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM2360E |
Features | Samsung Smart Control included, SolarCell remote |
Audio System | |
Output Power / Total | 20 Watt |
Features | Bluetooth Audio Streaming, Enhanced Audio Return Channel (eARC), Audio Pre-selection Descriptor, Adaptive Sound, Q-Symphony, Object Tracking Sound Lite, Dual Audio support, Buds Auto Switch |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11ac |
Bluetooth Version | Bluetooth 5.2 |
Connect & Share | Screen Mirroring, ConnectShare, Smart Hub, Sound Mirroring, Tap View, Media Home |
Supported Consumer Electronics Control (CEC) | Anynet Plus, Multiroom Link |
Connections | |
Connector Type | 3 x HDMI , 2 x USB , LAN , Digital audio output (optical) |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Compliant Standards | CEC, HGiG |
Power | |
Power Device | Power supply |
Input Voltage | AC 220-240 V (50/60 Hz) |
Auto On/Off | Yes |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 167.67 cm x 2.66 cm x 96.03 cm x 31.4 kg , Panel with stand - 167.67 cm x 33.19 cm x 100.34 cm x 32 kg , Stand - 126.68 cm x 33.19 cm |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 183.4 cm |
Depth (Shipping) | 19 cm |
Height (Shipping) | 111 cm |
Weight (Shipping) | 42.3 kg |
