3M 19" Wide TFT Privacy Screen
CLEARANCE
LAST FEW REMAINING
PRICE DROP
PRICE DROP!
£58.50
Delivery:
Key features
  • Excellent for high traffic areas
  • Protects your LCD panel from scratches and abrasions
  • Two unique attachment systems
  • Accessory Type: Privacy Screen
  • Stock Status: Used Stock
Product codes
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 18 15/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 16 1/16" wide x 10 1/16" high (408 mm x 255 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
Product Description 3M PF19.0W - display privacy filter - 19" wide
Product Type Display privacy filter
Display Screen Size Compatibility 19" wide
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: 6L64 039435
£8.83
product
Ref: 6L64 039435
Accessories
Packaging
Functional
Software
Manuals
£8.83
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M 19" Wide TFT Privac...
£58.50
