3M 22" Wide LCD Privacy Filter
CLEARANCE
LAST FEW REMAINING
PRICE DROP
£80.38
Delivery:
Key features
  • Effective "black out" privacy from side views outside the 60-degree viewing angle
  • Helps reduce reflections so you see your screen clearly with pristine image clarity
  • Reversible between a glossy side and glare-reducing matte
  • Designed with advanced microlouver technology, creating an excellent high-resolution viewing experience
  • Matte surface helps reduce glare and hide fingerprints
  • Easy to attach, remove and clean
Product codes
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 22" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 18 11/16" wide x 11 11/16" high (474 mm x 297 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
Product Description 3M Privacy Filter for 22" Widescreen Monitor - display privacy filter - 22" wide
Product Type Display privacy filter
Colour Black
Display Screen Size Compatibility 22" wide
Dimensions (WxDxH) 47.4 cm 29.7 cm
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M 22" Wide LCD Privac...
£80.38
