3M 23.8" Privacy Filter
£93.06
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • PF23.6W9 fits widescreen size desktop LCD monitors with a diagonally measured 23.8" (604.5 mm) viewable screen
  • Actual filter dimensions are 11 11/16" high x 20 3/4" wide (297 mm x 527.6 mm)
  • This filter is designed for widescreen LCD monitors that appear more rectangular than square have a 16:9 aspect ratio
  • Utilizes 3M's microlouver privacy technology so only persons directly in front of the monitor can see the image on screen
  • Reversible for either glossy or matte screen finish
  • Protects fragile LCD screens from scratches and abrasions
  • Accessory Type: Privacy Screen
  • Stock Status: In Stock
Product codes
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 23 13/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 3/4" wide x 11 11/16" high (528 mm x 297 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
Product Description 3M Privacy Filter PF23.8W9 - display privacy filter - 23.8" wide
Product Type Display privacy filter
Colour Black
Display Screen Size Compatibility 23.8" wide
Dimensions (WxDxH) 52.76 cm 29.7 cm
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£93.06
