3M 30.0" Widescreen (16:10) Monitor Privacy Filter - Fra...
3M 30.0" Widescreen (16:10) Monitor Privacy Filter - Frameless
£109.17
Delivery:
Key features
  • PF30.0W fits widescreen desktop monitors with a diagonally measured 30.0" viewing screen
  • Designed for widescreen desktop monitors with screens that appear more rectangular than square
  • Helps keep confidential and private information safe
  • Utilizes 3M's microlouver privacy technology so only persons directly in front of the monitor can see the image on screen
  • Passersby see only a dark screen
  • Excellent for high traffic areas
Product codes
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 29 3/4" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 25 3/16" wide x 15 3/4" high (641 mm x 401 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
Product Description 3M PF30.0W - display privacy filter - 30" wide
Product Type Display privacy filter
Display Screen Size Compatibility 30" wide
Dimensions (WxDxH) 64.1 cm 40.1 cm
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M 30.0" Widescreen (1...
£109.17
