3M Anti-Glare Filter 23" Frameless
£82.77
Delivery:
Key features
  • Helps reduce glare and mirror-like reflections
  • Lightweight, thin, frameless design
  • Filter is easily applied and reapplied numerous times; no lamination, no bubbles
  • Protects screen against scratches
  • Compatible with most touch-screen displays
  • Hides fingerprints
Product codes
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 23" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 1/16" wide x 11 5/16" high (510 mm x 287 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
Product Description 3M Anti-Glare Filter AG23.0W9 - display screen filter - 23" wide
Product Type Display screen filter
Package Content Cleaning cloth
Colour Clear
Display Screen Size Compatibility 23" wide
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M Anti-Glare Filter 2...
£82.77
