3M Anti-Glare Filter AG19.0W Display Screen Filter - 19"...
3M Anti-Glare Filter AG19.0W Display Screen Filter - 19" Wide
£55.05
Delivery:
Standard: 1-3 working days
Key features
  • Diffuses light so your screen is easier to see in challenging and changing indoor lighting conditions, brightly lit indoor areas and near windows
  • Helps reduce mirror-like reflections from indoor bright lights
  • Compatible with most touchscreen displays
  • Satin-like matte surface cleans easily and hides fingerprints
  • Lightweight, thin design
  • Designed to seamlessly fit within the raised bezel of your device
  • Accessory Type: Privacy Screen
  • Stock Status: In Stock
Product codes
Display and device technology continues to advance. So do we. Behind the simplicity of our products is a powerful combination of optical science and sheer ingenuity you’ve come to expect from 3M. Our anti-glare solutions work simply and beautifully on most of today’s monitors — including touchscreens — to help protect your screen and improve your view in indoor bright or challenging lighting conditions. Amazing optical technology from 3M diffuses mirror-like reflections to help keep what’s on your screen clear and visible, while providing a layer of protection from dust and scratches.
Product Description 3M Anti-Glare Filter for 19" Monitors 16:10 - display anti-glare filter - 19" wide
Product Type Display anti-glare filter
Colour Clear
Display Screen Size Compatibility 19" wide
Dimensions (WxDxH) 40.89 cm 25.65 cm
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£55.05
