3M Anti-Glare Filter AG200W9B 20" Wide
£67.99
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Diffuses light so your screen is easier to see in challenging and changing indoor lighting conditions, brightly lit indoor areas and near windows
  • Helps reduce mirror-like reflections from indoor bright lights
  • Compatible with most touchscreen displays
  • Satin-like matte surface cleans easily and hides fingerprints
  • Lightweight, thin design
  • Designed to seamlessly fit within the raised bezel of your device
  • Stock Status: In Stock
Product codes
Display and device technology continues to advance. So do we. Behind the simplicity of our products is a powerful combination of optical science and sheer ingenuity you’ve come to expect from 3M. Our anti-glare solutions work simply and beautifully on most of today’s monitors—including touchscreens—to help protect your screen and improve your view in indoor bright or challenging lighting conditions. Amazing optical technology from 3M diffuses mirror-like reflections to help keep what’s on your screen clear and visible, while providing a layer of protection from dust and scratches.
Product Description 3M Anti-Glare Filter for 20" Widescreen Monitor  - display anti-glare filter - 20" wide
Product Type Display anti-glare filter
Colour Clear
Display Screen Size Compatibility 20" wide
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M Anti-Glare Filter A...
£67.99
