3M Desktop Monitor Privacy Filter - Frameless - Widescreen
£80.24
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 3M microlouver privacy technology provides privacy screen protection for sensitive data
  • Reversible glossy or matte screen finish; matte screen finish reduces discomfort from screen glare
  • Two easy on, easy off attachment systems; simple to remove for easy screen sharing
  • Desktop monitor user working in sensitive areas; open plan offices, open reception areas
  • Protecting confidential/sensitive information - customer, commercial, medical, government, e-examination
  • Accessory Type: Privacy Screen
  • Stock Status: In Stock
Product codes
The Privacy Filters PF21.5W9 are designed to fit widescreen desktop monitors with a viewable screen size of 21.5". Using 3M microlouver technology the filter gives full 60° privacy protection on either side, protecting sensitive information from unauthorized viewing. With a simple attachment system the filter can be easily removed for screen sharing.
Product Description 3M Privacy Filter PF21.5W9 - display privacy filter - 21.5" wide
Product Type Display privacy filter
Display Screen Size Compatibility 21.5" wide
Dimensions (WxDxH) 47.7 cm 26.8 cm
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M Desktop Monitor Pri...
£80.24
