3M Laptop Privacy Filter 12.5" Wide
£35.83
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Microlouver technology delivers world-class effective "black out" privacy from side views outside the 60-degree viewing angle
  • Includes COMPLY Attachment System to quickly and easily switch from world-class privacy to screen sharing with one simple flip
  • Reversible between a glossy side and glare-reducing matte
  • Reduces 35% of blue light transmission from the display
  • COMPLY Attachment System uses a proprietary hinge design to withstand the rigors of daily use
  • Helps reduce reflections so you see your screen clearly with pristine image clarity
  • Matte surface helps reduce glare and hide fingerprints
  • Designed with advanced microlouver technology, creating an excellent high-resolution viewing experience
  • Designed to seamlessly fit within the raised bezel of your device
  • Easy to attach, remove and clean
  • Stock Status: In Stock
Product codes
Display and device technology continues to advance. So do we. Behind the simplicity of our products is a powerful combination of optical science and sheer ingenuity you’ve come to expect from 3M. The microlouver technology in our world-class privacy filter helps protect the confidential and sensitive information displayed on your screen. The matte surface helps reduce glare and hide fingerprints, so you get crisp image clarity on your laptop, while visual hackers with side views are kept in the dark.
Product Description 3M Privacy Filter for 12.5" Widescreen Laptop with COMPLY Attachment System notebook privacy filter
Product Type Notebook privacy filter
Package Content COMPLY attachment system, attachment strips
Colour Black
Display Screen Size Compatibility 12.5" wide
Features Anti-glare, reversible, Micro-Louver technology, 60° viewing, landscape mounting
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M Laptop Privacy Filt...
£35.83
