3M MicroTouch M1700SS Serial 17" 1280x1024 9ms VGA DVI-D...
3M MicroTouch M1700SS Serial 17" 1280x1024 9ms VGA DVI-D LCD Monitor
£653.95
Delivery:
Key features
  • All-glass, one-layer solution
  • 3M ClearTek hard coat
Product codes
The 3M MicroTouch Display M1700SS (17"), a purpose-built, surface capacitive touch display, provides a cost-competitive touch alternative to 5-wire resistive display solutions.
The display offers a stable base, highly durable touch screen, brilliant optics and a hidden cable management system, all in an elegant and simple-to-use design. This display easily integrates into numerous point-of-sale, PC, and thin client systems making it ideal for applications requiring long life and 24/7 uptime.
The M1700SS uses the 3M MicroTouch ClearTek II system which provides superior optics, durability from contaminants like dust, liquid and grime and speed for high transaction based environments.
Product Description 3M MicroTouch M1700SS Serial - LCD monitor - 17"
Device Type LCD monitor - 17" - touchscreen
Features Touch-screen
Native Resolution 1280 x 1024 at 60 Hz
Pixel Pitch 0.264 mm
Brightness 270 cd/m²
Contrast Ratio 800:1
Response Time 9 ms
Colour Support 16.2 million colours
Input Connectors DVI-D, VGA
Colour Black
Dimensions (WxDxH) 40.5 cm x 24.7 cm x 41.3 cm
Weight 8.6 kg
Compliant Standards FCC Class B certified, UL, C-Tick, cUL, VESA DPMS, CCC, RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
3M MicroTouch M1700SS...
£653.95
