3M PF27.0W LCD PRIVACY FILTER
£107.12
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • PF27.0W fits widescreen desktop monitors with a diagonally measured 27.0" viewing screen
  • Actual filter dimensions are 22.93" wide x 14.34" high
  • This filter is designed for widescreen desktop monitors with screens that appear more rectangular than square
  • Helps keep confidential and private information safe
  • Utilizes 3M's microlouver privacy technology so only persons directly in front of the monitor can see the image on screen
  • Passersby see only a dark screen
  • Excellent for high traffic areas
  • Reversible for either glossy or matte screen finish
  • Reduces reflections when used with the matte side facing you
  • Helps to protect your LCD panel from scratches and abrasions
  • Easy on easy off attachment system
Product codes
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 27 1/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 22 15/16" wide x 14 5/16" high (582 mm x 364 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments. Limited 1-year warranty.
3M PF27.0W - display privacy filter - 27" wide
Display privacy filter
Display Screen Size Compatibility
27" wide
58.2 cm 36.4 cm
1 year warranty
Customer reviews
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: 81QR 025143
£15.02
product
Ref: 81QR 025143
Accessories
Packaging
Functional
Software
Manuals
£15.02
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M PF27.0W LCD PRIVACY...
£107.12
