3M Privacy Filter 23" Wide
Key features
  • 3M Privacy Filters give full 60° protection from either side
  • Prevents anyone reading your screen when using your computer in public
  • Easy to remove when sharing data with friends or colleagues
Product codes
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 23" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 1/16" wide x 11 5/16" high (510 mm x 287 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
Product Description 3M Privacy Filter PF23.0W9 - display screen filter - 23" wide
Product Type Display screen filter
Display Screen Size Compatibility 23" wide
Dimensions (WxDxH) 61 cm 28.8 cm
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
3M Privacy Filter 23"...
