3M Privacy Filter for 19" Standard Monitor - Display pri...
3M Privacy Filter for 19" Standard Monitor - Display privacy filter - 19" - black
£59.84
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Effective "black out" privacy from side views outside the 60-degree viewing angle
  • Helps reduce reflections so you see your screen clearly with pristine image clarity
  • Reversible between a glossy side and glare-reducing matte
  • Designed with advanced microlouver technology, creating an excellent high-resolution viewing experience
  • Matte surface helps reduce glare and hide fingerprints
  • Easy to attach, remove and clean
  • Adds an extra layer of protection from everyday scratches and dust
  • Designed to seamlessly fit within the raised bezel of your device
  • Reduces 35% of blue light transmission from the display
  • 100% hand inspected for quality assurance
  • Stock Status: In Stock, Used Stock
Product codes
Display and device technology continues to advance. So do we. Behind the simplicity of our products is a powerful combination of optical science and sheer ingenuity you’ve come to expect from 3M. The microlouver technology in our world-class privacy filter helps protect the confidential and sensitive information displayed on your monitor from the side-views of visual hackers. The matte surface helps reduce glare and hide fingerprints, so you get crisp image clarity on your screen, while visual hackers with side views are kept in the dark.
Product Description 3M Privacy Filter for 19" Standard Monitor - display privacy filter - 19"
Product Type Display privacy filter
Colour Black
Display Screen Size Compatibility 19"
Manufacturer Warranty 1-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: D6SN 037801
£8.30
product
Ref: D6SN 037801
Accessories
Packaging
Functional
Software
Manuals
£8.30
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
3M Privacy Filter for...
£59.84
