Acer Aspire Chromebook Celeron N3060 4GB 32GB SSD 14" Ch...
Acer Aspire Chromebook Celeron N3060 4GB 32GB SSD 14" Chrome OS
£279.43
Delivery:
Key features
  • Strength in housing
  • Screening room
  • Long battery life
  • Faster wireless
  • Better video chats
  • Display Size: 14in
  • Processor Model: N3060
  • Operating System: Google Chrome OS
  • Installed Memory: 4GB, 4GB
  • Hard Drive Capacity: 32GB
Product codes
The Acer Chromebook 14 has everything you’d expect and then gives you more. For one thing, it’s completely encased in aluminum alloy. Then you get a bigger 14-inch anti-glare HD or Full HD screen, up to 12 hours of battery life and enhanced wireless speeds. And did we mention it’s absolutely stunning?
Product Description Acer Chromebook 14 CB3-431-C6WH - 14" - Celeron N3060 - 4 GB RAM - 32 GB eMMC - UK
Product Type Chromebook
Operating System Chrome OS
Processor Intel Celeron N3060 / 1.6 GHz (2.48 GHz) / 2 MB Cache
Memory 4 GB LPDDR3 (provided memory is soldered)
Storage 32 GB - eMMC
Display 14" LED backlight 1366 x 768 / HD
Graphics Intel HD Graphics 400
Keyboard UK
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2
Battery 3-cell
Colour Sparkly silver
Dimensions (WxDxH) 34.1 cm x 23.66 cm x 1.695 cm
Weight 1.677 kg
Localisation Region: United Kingdom
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer
Ref: C52D 041172
£173.35
product
Ref: C52D 041172
Accessories
Packaging
Functional
Software
Manuals
£173.35
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer Aspire Chromebook...
£279.43
