The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
Product Description | Acer B227Q bmiprzx - B7 Series - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class F | Energy Consumption per Year | 30 kWh | Power Consumption (On mode) | 21 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz) | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 49 cm x 19.3 cm x 48.5 cm | Weight | 4.78 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Bronze |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM), ComfyView, Adaptive-Sync technology, 3-sided bezeless |
Colour | Black |
Dimensions (WxDxH) | 49 cm x 19.3 cm x 48.5 cm - with stand |
Weight | 4.78 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DisplayPort , HDMI , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+25 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable , 1 x VGA cable , 1 x SuperSpeed USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 19 kWh/1000h |
Power Consumption (Typical) | 13 Watt |
Power Consumption Stand by | 0.32 Watt |
Power Consumption Sleep | 0.32 Watt |
Power Consumption (Off Mode) | 0.23 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 49 cm - depth: 19.3 cm - height: 48.5 cm - weight: 4.78 kg , Without stand - width: 49 cm - depth: 6.5 cm - height: 29.5 cm - weight: 2.83 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Bronze |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
