The Acer B248Y is an ergonomic monitor that has been designed around cushioning various pain points that come up in a day's work. TÜV/Eyesafe certified, the monitor includes a number of features that aim to reduce eye-strain, such as Acer LightSense and Acer ColorSense, which automatically adjust screen brightness and color temperature to match the environment. The monitor's FHD (1980 x 1080) IPS display sits on an Ergostand, a flexible stand that makes it easy to adjust the display's height, swivel or tilt, or even rotate 90 degrees into portrait mode.
Easy on the eyes, the B248Y can also make the most of any desk. Its built-in docking station turns the monitor into a workspace in its own right, serving to remove clutter and making use of RJ45 and USB Type-C 100W PD ports which simplify the process of moving work from office to office, or back home. Multiple monitors can be daisy-chained together, for those who need more screen real estate, and an adjustable FHD webcam that supports Windows Hello enables users to rotate the camera's feed until they find the perfect angle, or physically close it to avoid accidental sharing during a meeting.
Product Description | Acer B248Y bemiqprcuzx - B8 Series - LED monitor - Full HD (1080p) - 23.8" - HDR | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Power Consumption (On mode) | 17 W | Adaptive-Sync Technology | VESA Adaptive-Sync | Features | Microphone, USB 3.0 hub, FHD camera | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | HDR Capable | HDR10 | Response Time | 4 ms (grey-to-grey) | Input Connectors | HDMI, DisplayPort, USB-C | Built-in Ethernet | Yes | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Environmental Standards | TCO Certified Displays 8, TCO Certified Displays 9 EPEAT Bronze | Compliant Standards | DisplayPort 1.4, TUV Eyesafe Display Certification |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class F |
Diagonal Size | 23.8" |
Built-in Devices | Microphone, USB 3.0 hub, FHD camera |
Panel Type | IPS |
HDR Format | HDR10 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ComfyView, Zero Frame, Acer VisionCare, 3-sided bezeless, Delta E<1 calibration, Eyesafe technology |
Colour | Black |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | HDMI , DisplayPort 1.4 , DisplayPort output , USB-C with Power Delivery (power up to 100W) , Network (RJ-45) , Audio line-out , 2 x USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 120 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 1 x HDMI cable , 1 x USB-C cable , 1 x SuperSpeed USB cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17 kWh/1000h |
Power Consumption HDR (On mode) | 20 kWh/1000h |
Software / System Requirements | |
Included Software | Acer Smart Console |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Displays 9 |
EPEAT Compliant | EPEAT Bronze |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
