The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment. Acer EcoDisplay Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. ComfyView Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods. ErgoStand The ergonomic design of this monitor optimizes the viewing position for maximum comfort even during prolonged use.
Product Description | Acer B276HLCbmdprx - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 6 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | DVI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Colour | Dark grey | Dimensions (WxDxH) - with stand | 63.97 cm x 22.09 cm x 40.66 cm | Environmental Standards | TCO Certified Displays 7, ENERGY STAR Qualified | Manufacturer Warranty | 3-year warranty | Designed For | TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N; TravelMate X3 TMX3410-M-52M7; X5 TMX514-51-560Q, TMX514-51T-54EG |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ErgoStand, Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Acer eColor technology, 6-bit gamma |
Dimensions (WxDxH) | 63.97 cm x 22.09 cm x 40.66 cm - with stand |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI , DisplayPort , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 120 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Included Accessories | Stand |
Cables Included | 1 x VGA cable - VGA to VGA , 1 x DVI cable , 1 x DisplayPort cable - DisplayPort to DisplayPort |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 63.97 cm - depth: 22.09 cm - height: 40.66 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm |
Environmental Standards | |
ENERGY STAR Certified | Yes |
TCO Certified | TCO Certified Displays 7 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in |
Compatibility Information | |
Designed For | Acer TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N , Acer TravelMate X3 TMX3410-M-52M7 , Acer TravelMate X5 TMX514-51-560Q, TMX514-51T-54EG |
