The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
Product Description | Acer B277bmiprzx - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.5 cm x 20.6 cm x 52.1 cm | Weight | 10.2 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ComfyView, Zero Frame, Flicker-Less technology, Low Dimming technology, Adaptive-Sync technology, Acer VisionCare, Acer BluelightShield technology |
Colour | Black |
Dimensions (WxDxH) | 61.5 cm x 20.6 cm x 52.1 cm - with stand |
Weight | 10.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DisplayPort , HDMI , Audio line-in , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream |
Mechanical | |
Tilt Angle | -5/+25 |
Swivel Angle | 90 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand |
Cables Included | 1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26.1 kWh/1000h |
Power Consumption (Typical) | 16.17 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.5 cm - depth: 20.6 cm - height: 52.1 cm - weight: 10.2 kg , Without stand - width: 61.4 cm - depth: 6.6 cm - height: 36.7 cm - weight: 5 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
