Acer B277U 27" 2560x1440 4ms HDMI DP LED Monitor
£471.56
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • ZeroFrame design
  • Strong, ergonomic edge
  • Built-in speaker
  • Acer VisionCare
  • Wide range of color
  • Designed for accuracy
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
Product Description Acer B277U - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 52 kWh
Power Consumption (On mode) 24 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440 at 75 Hz
Brightness 350 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Dimensions (WxDxH) - with stand 61.4 cm x 20.75 cm x 54 cm
Weight 8.22 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer B277U 27" 2560x14...
£471.56
