Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision. The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
Product Description | Acer B277U bmiipprzx - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 52 kWh | Power Consumption (On mode) | 36 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 at 75 Hz | Pixel Pitch | 0.233 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 1.07 billion colours | Colour Gamut | 100% sRGB | Input Connectors | 2xHDMI, DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.4 cm x 20.8 cm x 40.1 cm | Weight | 7.77 kg | Environmental Standards | TCO Certified Displays 8 EPEAT Bronze | Compliant Standards | DisplayPort 1.2 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 120 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ErgoStand, Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, Super Sharpness technology, Adaptive-Sync technology, Acer VisionCare, Acer BluelightShield technology, 6-Axis Color Adjustments, Acer ColorPlus technology, Acer Display Widget, 3-sided bezeless |
Colour | Black |
Dimensions (WxDxH) | 61.4 cm x 20.8 cm x 40.1 cm - with stand |
Weight | 7.77 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort 1.2 , Mini DisplayPort , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+25 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable , 1 x SuperSpeed USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 32.1 kWh/1000h |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.41 Watt |
Power Consumption (Off Mode) | 0.28 Watt |
On / Off Switch | Yes |
Dimensions & Weight (Shipping) | |
Shipping Weight | 10.81 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Bronze |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
