We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
Product Description | Acer B287K bmiipprzx - LED monitor - 4K - 28" - HDR | Device Type | LED-backlit LCD monitor - 28" | Energy Class | Class G | Energy Consumption per Year | 54 kWh | Power Consumption (On mode) | 31 W | Adaptive-Sync Technology | AMD Adaptive-Sync | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.16 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | HDR Capable | HDR10 | Response Time | 4 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 90% DCI-P3 | Input Connectors | 2xHDMI, DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 63.7 cm x 20.8 cm x 52.4 cm | Weight | 7.5 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 28" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
HDR Format | HDR10 |
Vertical Refresh Rate | 40 - 60 Hz |
Horizontal Refresh Rate | 30 - 160 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM), Adaptive-Sync technology, 3-sided bezeless, 8-bit + FRC Colour Depth |
Colour | Black |
Dimensions (WxDxH) | 63.7 cm x 20.8 cm x 52.4 cm - with stand |
Weight | 7.5 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Mini DisplayPort , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+25 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable , 1 x SuperSpeed USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 31 kWh/1000h |
Power Consumption HDR (On mode) | 45 kWh/1000h |
Power Consumption Stand by | 0.45 Watt |
Power Consumption Sleep | 0.45 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 63.7 cm - depth: 20.8 cm - height: 52.4 cm - weight: 7.5 kg , Without stand - width: 63.7 cm - depth: 6.8 cm - height: 37.1 cm - weight: 5.28 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
