Ideal for use in office environments, libraries and computer labs, B6 Series monitors deliver dynamic and energizing visuals thanks to their high display resolution and true-to-life colors. They also feature an ergonomic design for comfortable all-day computing, and they use eco-friendly technologies to save power and cut energy costs.
Product Description | Acer B326HK - LED monitor - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class C | Energy Consumption per Year | 93 kWh | Power Consumption (On mode) | 64 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI/MHL: 30 Hz, DVI: 30 Hz) | Brightness | 350 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 6 ms | Colour Support | 1.07 billion colours | Input Connectors | DVI, HDMI, MHL, DisplayPort, Mini DisplayPort | Speakers | Internal | Display Position Adjustments | Height, swivel, tilt | Colour | Dark grey | Dimensions (WxDxH) - with stand | 73.79 cm x 26.65 cm x 62.34 cm | Weight | 12 kg | Localisation | United Kingdom, Europe | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM) |
Dimensions (WxDxH) | 73.79 cm x 26.65 cm x 62.34 cm - with stand |
Weight | 12 kg |
Audio | |
Type | Speakers - internal |
Connectivity | |
Interfaces | MHL / HDMI , DVI , DisplayPort , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+25 |
Height Adjustment | 150 mm |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable , 1 x DVI cable , 1 x SuperSpeed USB cable |
Power | |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 44 Watt |
Power Consumption Stand by | 390 mW |
Power Consumption Sleep | 320 mW |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 73.79 cm - depth: 6.2 cm - height: 45.36 cm - weight: 7.95 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in |
