Acer B346CKbmijphzx 34" 3440x1440 HDMI DP USB Monitor
£629.43
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Ultra-wide 34-inch IPS screens provide wide viewing angles up to 178 degrees
  • Excellent color accuracy with 100 percent sRGB and 6-axis color adjustment
  • Easy multitasking with PIP (picture-in-picture)
  • Superb connectivity via HDMI with MHL charging, DisplayPort and a USB 3.0 hub
  • EPEAT Gold rated, ENERGY STAR and TCO 6.0 qualified
Product codes
The ultra-wide screens and picture-by-picture capability make it possible to view large spreadsheets, brochures, newsletters and two documents side by side. Picture-in-picture capability enables customers to watch a movie in a box on the screen, while working on a project. Thanks to an IPS panel, wide 178-degree viewing angles enhance visual collaboration with others on joint projects.
The display meet the highest standards for color accuracy with 100 percent sRGB coverage and 6-axis color adjustment. Both displays have a 21:9 aspect ratio, while the Acer B346CK delivers 3202 cd/m brightness and 1.07 billion colors. A crisp 100,000,000:1 maximum contrast ratio and a 6 ms response time contribute to the stunning picture quality. Acer ComfyView non-glare protection provides clearer, more comfortable viewing via a polarizer material to reduce reflections.
VESA compliant, the displays can be mounted on a wall to save valuable desk space and two 3 W speakers provide quality audio. Optimized for maximum comfort, a multi-function ErgoStand provides tilt adjustable 25 degrees up or -5 degrees down, swivel 60 degrees to the right or left, and height up to 5.9 inches up or down. Connectivity options feature HDMI with MHL for charging portable devices, DisplayPort and a USB 3.0 hub for connecting multiple peripherals simultaneously.
In addition to being ENERGY STAR and TCO 6.0 qualified, the Acer B346CK is EPEAT Gold registered, the highest level of EPEAT registration available. Mercury-free and LED-backlit, these monitors reduce energy costs by consuming less power than standard CCFL-backlit displays and are safer for the environment.
Acer B346CK - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
88 kWh
Power Consumption (On mode)
61 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440
Brightness
320 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, HDMI (MHL)
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
82.8 cm x 26.67 cm x 58.93 cm
9.98 kg
RoHS, TCO Displays 6.0
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer B346CKbmijphzx 34...
£629.43
