The ultra-wide screens and picture-by-picture capability make it possible to view large spreadsheets, brochures, newsletters and two documents side by side. Picture-in-picture capability enables customers to watch a movie in a box on the screen, while working on a project. Thanks to an IPS panel, wide 178-degree viewing angles enhance visual collaboration with others on joint projects.
The display meet the highest standards for color accuracy with 100 percent sRGB coverage and 6-axis color adjustment. Both displays have a 21:9 aspect ratio, while the Acer B346CK delivers 3202 cd/m brightness and 1.07 billion colors. A crisp 100,000,000:1 maximum contrast ratio and a 6 ms response time contribute to the stunning picture quality. Acer ComfyView non-glare protection provides clearer, more comfortable viewing via a polarizer material to reduce reflections.
VESA compliant, the displays can be mounted on a wall to save valuable desk space and two 3 W speakers provide quality audio. Optimized for maximum comfort, a multi-function ErgoStand provides tilt adjustable 25 degrees up or -5 degrees down, swivel 60 degrees to the right or left, and height up to 5.9 inches up or down. Connectivity options feature HDMI with MHL for charging portable devices, DisplayPort and a USB 3.0 hub for connecting multiple peripherals simultaneously.
In addition to being ENERGY STAR and TCO 6.0 qualified, the Acer B346CK is EPEAT Gold registered, the highest level of EPEAT registration available. Mercury-free and LED-backlit, these monitors reduce energy costs by consuming less power than standard CCFL-backlit displays and are safer for the environment.
Product Description | Acer B346CK - LED monitor - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class C | Energy Consumption per Year | 88 kWh | Power Consumption (On mode) | 61 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | QHD 3440 x 1440 | Brightness | 320 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 6 ms | Colour Support | 1.07 billion colours | Input Connectors | HDMI, DisplayPort, HDMI (MHL) | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) - with stand | 82.8 cm x 26.67 cm x 58.93 cm | Weight | 9.98 kg | Compliant Standards | RoHS | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 34" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM), ComfyView |
Colour | Black |
Dimensions (WxDxH) | 82.8 cm x 26.67 cm x 58.93 cm - with stand |
Weight | 9.98 kg |
Audio | |
Type | Speakers - stereo |
Connectivity | |
Interfaces | MHL / HDMI , HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out |
Mechanical | |
Tilt Angle | -5/+25 |
Swivel Angle | 60 |
Height Adjustment | 150 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 1 x DisplayPort cable , 1 x SuperSpeed USB cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 53.5 Watt |
Power Consumption Stand by | 500 mW |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in |
