Acer B6 Series B226WL 22" 1680 x 1050 5ms VGA DVI LED Mo...
Acer B6 Series B226WL 22" 1680 x 1050 5ms VGA DVI LED Monitor
£154.20
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Gives you clear views with more room
  • Superior contrast ratios and ultra-quick response
  • Faster and more productive
  • RoHS compliant
Product codes
Find the working angle that's perfect for you with a monitor that tilts, swivels, pivots and can be adjusted for height. The stand also has a magnetic area, perfect for holding paperclips and keeping your desk uncluttered. The monitor is also wall-mountable, giving you clear views with more room.
Product Description Acer B226WLymdr - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI, VGA
Speakers Internal
Display Position Adjustments Height, pivot (rotation), tilt
Colour Dark grey
Dimensions (WxDxH) 50.58 cm x 22.12 cm x 33.41 cm
Weight 5.75 kg
Environmental Standards ENERGY STAR Qualified EPEAT Gold
Compliant Standards TUV GS, ISO 9241-307, TCO Displays 6.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer B6 Series B226WL...
£154.20
