Acer CB241HBMIDR 24'' FHD LED Monitor 1ms 250nits DVI...
Acer CB241HBMIDR 24'' FHD LED Monitor 1ms 250nits DVI HDMI MM H
£151.05
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Full HD
  • 1 ms response time
  • Acer eColor
  • VESA mount
  • Flicker-less technology
  • 6-axis color tuning
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
The Acer CB series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus they are designed to save power and costs.
Product Description Acer CB241H - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class B
Energy Consumption per Year 48 kWh
Power Consumption (On mode) 33 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.276 mm
Brightness 250 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 56.7 cm x 21.66 cm x 37.93 cm
Weight 6 kg
Compliant Standards VCCI, CCC, FCC, ISO 9241-307, DDC-2B/CI, EAC, TUV Rheinland, NOM-NYCE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer CB241HBMIDR 24''...
£151.05
