Enjoy an outstanding visual experience with a CB2 Series ZeroFrame monitor, designed with prosumers in mind.
Product Description | Acer CB342CK Csmiiphuzx - CB2 Series - LED monitor - 34" - HDR | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Energy Consumption per Year | 50 kWh | Power Consumption (On mode) | 34 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | UWQHD 3440 x 1440 | Brightness | 400 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | HDR Capable | DisplayHDR 400 | Response Time | 1 ms (VRB) | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, DisplayPort, USB-C | Display Position Adjustments | Height, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black, silver | Dimensions (WxDxH) - with stand | 81.7 cm x 26.9 cm x 44.7 cm | Weight | 8.7 kg | Compliant Standards | MPR II |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 34" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
HDR Certification | DisplayHDR 400 |
Horizontal Refresh Rate | 15 - 222 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Dimensions (WxDxH) | 81.7 cm x 26.9 cm x 44.7 cm - with stand |
Weight | 8.7 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , USB-C , 2 x USB 3.0 downstream , USB 3.0 upstream |
Mechanical | |
Tilt Angle | -5/+35 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 1 x HDMI cable , 1 x USB-C cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 34.3 kWh/1000h |
Power Consumption HDR (On mode) | 45.7 kWh/1000h |
On / Off Switch | No |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 81.7 cm - depth: 26.9 cm - height: 44.7 cm - weight: 8.7 kg , Without stand - width: 81.7 cm - depth: 5.86 cm - height: 36.7 cm - weight: 6.8 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
