Display finely detailed design concepts and complex 3D content with a ConceptD CP3 series monitor. These PANTONE® Validated 4K UHD displays provide professional color accuracy with Delta E <1 and 90% DCI-P3. Enjoy pristine HDR images with VESA DisplayHDR™ 400 Certification and eliminate visual artifacts with this NVIDIA® G-SYNC® Compatible display.
Color Accuracy
Professional design work requires professional tools, and ConceptD CP3 monitors feature 27" IPS displays with 4K UHD resolution, backed up by color technologies that ensure vivid, true-to-life color reproduction. Optimize your monitor’s color profile with the click of a button with the Color Calibrator.
Delta E <1
The display has been tested and calibrated to achieve a low Delta E average of <1 to reproduce true-to-life color accuracy.
PANTONE® Validated
Get a professional edge with a display that features integrated color correction and has demonstrated superior fidelity in reproducing the PANTONE Matching System (PMS) Colors.
3D Lookup Tables
Get professional color grading for digital and video. 3D lookup tables (3D LUTs) map one color space to another in order to ensure faithful color reproduction.
Wide Color Gamut
Get brighter and more lifelike colors with 90% DCI-P3, and enjoy smooth transitions, finer shades, and a uniform appearance. DCI-P3 is an international color standard used by directors and producers. Now integrated into devices, colors are reproduced to match this professional-grade quality, making it ideal for high-level editing in video and film.
Unbelievable 4K Clarity
Once you’ve worked on a 4K screen, you’ll never settle for less. With 3840 x 2160 resolution, you can see more, do more and enjoy beyond measure. Get better color reproduction at viewing angles of up to 178° with the IPS panel.
Fast-paced Frames
View and create hyper-smooth 2D and 3D motion scenes with a rapid refresh rate you can overclock to 144Hz. More frames per second means quicker frame rendering and a lower input lag.
Outstanding HDR Experience
Experience realistic, natural images through the expanded contrast ratio and color palette guaranteed by VESA Certificated DisplayHDR™ 400. Create images with improved brightness and contrast with darker blacks and whiter whites with greater depth and shadowing.
VESA Certified DisplayHDR™ 400
VESA Certified DisplayHDR™ 400 specifies HDR quality, including luminance, color gamut, bit depth, and rise time. The display features 400 nits peak brightness.
Effortless Performance
This NVIDIA® G-SYNC® Compatible display delivers super-smooth graphics and low latency with baseline variable refresh rates (VRR). Work on any project without tearing, stuttering, artifacts, and flicker in full-screen or windowed mode.
Designed for Creators
With its timeless design, a ConceptD CP3 monitor adorns any workplace, adding a touch of class with the natural appearance of the stand base. This monitor comes with plenty of ports, a built-in light sensor, and a light shielding hood, meaning it’s equipped for professional design work.
Smart Light Sensor
The built-in ambient light sensor automatically measures the brightness of the environment and adjusts the backlight accordingly, reducing eye strain.
Shaded for Accuracy
The light-shielding hood1 ensures ambient light is blocked and gives you relief from eyes strain and some added privacy when you need to work on confidential projects.
Product Description | Acer ConceptD CP3 CP3271KP - LED monitor - 4K - 27" - HDR | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Power Consumption (On mode) | 32 W | Adaptive-Sync Technology | NVIDIA G-SYNC | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 (DisplayPort(OC): 144 Hz, DisplayPort: 120 Hz, HDMI: 60 Hz) | Brightness | 400 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | HDR Capable | DisplayHDR 400 | Response Time | 1 ms (VRB) | Colour Support | 1.07 billion colours | Colour Gamut | 90% DCI-P3 | Input Connectors | 2xHDMI, 2xDisplayPort | Display Position Adjustments | Height, pivot (rotation), tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 62.9 cm x 26.9 cm x 60.05 cm | Weight | 6.53 kg | Compliant Standards | MPR II | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
HDR Certification | DisplayHDR 400 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM), Delta E<1 calibration, Pantone Validated |
Colour | Black |
Dimensions (WxDxH) | 62.9 cm x 26.9 cm x 60.05 cm - with stand |
Weight | 6.53 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 4 Watt |
Connectivity | |
Interfaces | 2 x HDMI , 2 x DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+35 |
Height Adjustment | 180 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 2 x DisplayPort cable , USB 3.0 upstream cable , HDMI cable , 2 x DisplayPort cable , USB 3.0 upstream cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 32 kWh/1000h |
Power Consumption HDR (On mode) | 65 kWh/1000h |
Power Consumption (Typical) | 39 Watt |
Power Consumption Sleep | 0.45 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 62.9 cm - depth: 26.9 cm - height: 60.05 cm - weight: 6.53 kg , Without stand - width: 62.9 cm - depth: 8.89 cm - height: 37.5 cm - weight: 4.44 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
