We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Shaping your viewing experience with a curved form factor that delivers the incredible.
Cutting-edge tech features allow you to immerse yourself in extraordinary visuals.
Product Description | Acer ED320QR Pbiipx - LED monitor - curved - Full HD (1080p) - 31.5" | Device Type | LED-backlit LCD monitor - 31.5" | Energy Class | Class F | Energy Consumption per Year | 50 kWh | Power Consumption (On mode) | 31.1 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 (DisplayPort: 165 Hz, HDMI: 144 Hz) | Pixel Pitch | 0.12125 mm | Brightness | 300 cd/m² | Contrast Ratio | 4000:1 / 100000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours (8-bit) | Colour Gamut | 72% NTSC | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 71.3 cm x 51.25 cm x 19.86 cm | Weight | 5.2 kg | Compliant Standards | MPR II, TUV GS, DDC-2B/CI, ISO 9241-307 Class 2 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 31.5" |
Curved Screen | Yes (1800R) |
Panel Type | VA |
Pixel Per Inch | 70 |
Vertical Refresh Rate | 48 - 165 Hz |
Horizontal Refresh Rate | 53.93 - 183.15 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, Acer VisionCare, Acer BluelightShield technology, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 71.3 cm x 51.25 cm x 19.86 cm - with stand |
Weight | 5.2 kg |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Audio line-out |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 31.1 kWh/1000h |
Power Consumption (Typical) | 25.94 Watt |
Power Consumption Stand by | 0.17 Watt |
Power Consumption (Off Mode) | 0.18 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 71.3 cm - depth: 51.25 cm - height: 19.86 cm - weight: 5.2 kg , Without stand - width: 71.3 cm - depth: 6.34 cm - height: 41.9 cm - weight: 3.75 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 6.7 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
