Acer ED322Q 31.5" 1920x1080 4ms VGA DVI HDMI LED Monitor
Select:
Key features
  • Curved immersion
  • Entertainment
  • Ports
Product codes
Immerse yourself in the graphics of work or play on this Acer curved monitor. The edge-to-edge frameless screen is a full 31.5 inches, wrapping you within the action of your favorite games and streaming movies. EyeProtect Flicker-Less and BlueLightShield technology on this Acer curved monitor defend your eyes from strain.
Product Description Acer ED322Q - LED monitor - curved - Full HD (1080p) - 31.5"
Device Type LED-backlit LCD monitor - 31.5"
Energy Class Class B
Energy Consumption per Year 62 kWh
Power Consumption (On mode) 42 W
Curved Screen Yes
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.36375 mm
Brightness 250 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour White
Dimensions (WxDxH) - without stand 71.1 cm x 20.8 cm x 52.6 cm
Weight 5.86 kg
Compliant Standards FCC Class B certified, MPR II, UL, TUV, VCCI, cUL, GS, NOM, RoHS, WEEE, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer ED322Q 31.5" 1920...
