Marketing description is not available.
Product Description | Acer ET430K - LED monitor - 4K - 43" | Device Type | LED-backlit LCD monitor - 43" | Energy Class | Class A | Energy Consumption per Year | 100 kWh | Power Consumption (On mode) | 69 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.2451 mm | Brightness | 350 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Input Connectors | 2xHDMI, DisplayPort, Mini DisplayPort | Display Position Adjustments | Tilt | Colour | White | Dimensions (WxDxH) | 96.6 cm x 24.3 cm x 65.3 cm | Weight | 12.36 kg | Compliant Standards | MPR II | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 43" |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | 72% NTSC colour gamut, ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology |
Colour | White |
Weight | 12.36 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 7 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort output , DisplayPort , Mini DisplayPort , Audio line-out |
Mechanical | |
Tilt Angle | -3.5/+11.5 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable , 1 x HDMI cable |
Power | |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 55 Watt |
Power Consumption Stand by | 0.45 Watt |
Power Consumption (Off Mode) | 0.35 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 85% (non-condensing) |
