Acer H277HK 27" 3480x2160 4ms HDMI DP USB3 LED Monitor
£559.29
Delivery:
Key features
  • Flicker-less technology
  • IPS display
Product codes
An Acer H7 Series monitor oozes style and quality. It combines an eye-pleasing and premium brushed-metal stand, a "zero-frame" screen, and a glossy back panel to create a truly lustrous effect. Its WQHD display, superior audio, superfast USB Type-C port, and HDMI 2.0 port makes it ideal for immersing you in perfectly portrayed high-resolution movies.
Acer H277HK - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
White, silver
61.27 cm x 21.72 cm x 43.87 cm
4.81 kg
Denmark, Finland, Norway, Sweden
Environmental Standards
ENERGY STAR Qualified
MPR II, TUV Rheinland
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer H277HK 27" 3480x2...
£559.29
