Acer K202HQLb 19.5" 1600x900 5ms VGA LED Black Monitor
£86.65
Delivery:
Standard: 1-3 working days
Key features
  • Slim and elegant
  • High resolution
  • Fast response time
  • Superior contrast ratio
  • RoHS compliant
  • LED backlighting
  • Diagonal Size: 19.5in
  • Max Resolution: 1600 x 900
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: VGA (HD-15)
Product codes
Everyday series monitor gives you the beauty you appreciate and the value you need. It showcases captivating widescreen visuals as well as eco-conscious features, making it perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Product Description Acer K202HQLb - LED monitor - 19.5"
Device Type LED-backlit LCD monitor - 19.5"
Panel Type TN
Aspect Ratio 16:9
Native Resolution 1600 x 900
Brightness 200 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) - without stand 46.34 cm x 5 cm x 27.62 cm
Weight 2.21 kg
Localisation United Kingdom, Europe, EMEA
Microsoft Certification Compatible with Windows 7
Compliant Standards MPR II
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer K202HQLb 19.5" 16...
£86.65
