Acer K242HLA 24" 1920x1080 5ms DVI VGA LED Monitor
£108.76
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 24" LED-backlit LCD monitor
  • Full HD 1080p (1920 x 1080)
  • 250nits brightness
  • 100000000: 1 contrast ratio
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Interfaces: DVI, VGA (HD-15)
  • Stock Status: In Stock
Product codes
The Acer K2 series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance.
Product Description Acer K242HL - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 34 kWh
Power Consumption (On mode) 23 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors DVI, VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 56.7 cm x 20.7 cm x 42.19 cm
Weight 3.57 kg
Localisation EMEA
Environmental Standards ENERGY STAR Qualified
Compliant Standards MPR II
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer K242HLA 24" 1920x...
£108.76
