The KA series is optimized for a comfortable viewing experience. The display is easy on the eyes with low response times and special technology to reduce glare and harsh blue light. Easy adjustments and a wide viewing angle help you find the perfect position.
Product Description | Acer KA270H Abid - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Energy Consumption per Year | 47 kWh | Power Consumption (On mode) | 26.1 W | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Weight | 5.4 kg | Compliant Standards | MPR II |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ComfyView, Flicker Free technology, blue light reduction, Wide Viewing Angle |
Colour | Black |
Dimensions (WxDxH) | - with stand |
Weight | 5.4 kg |
Connectivity | |
Interfaces | VGA , DVI , HDMI |
Mechanical | |
Tilt Angle | -5/+15 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x VGA cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26.1 kWh/1000h |
Power Consumption (Typical) | 26.6 Watt |
On / Off Switch | No |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - weight: 5.4 kg , Without stand - weight: 5 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
