Acer KG271U 27" 2xHDMI 2560 x 1440 LED Backlit
£274.16
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • High resolution
  • Lightning-fast response time
  • Ultra-low input lag technology
  • Ultra-low blue light technology
  • Flickerless technology
  • ComfyView display
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
Everything's better with more pixels. A high resolution makes textures crisp and clear. As you know, it's a resolution sweet spot for high-speed gaming. Acer monitor boasts a fast response time so all your fast-paced gaming action will be rendered smoothly without smearing, ghosting and motion blur. You'll be able to react and respond quickly to what you see onscreen - a definite advantage in the gaming arena. Acer monitor is equipped with an ultra-fast response time and low input lag technology for a lag-free experience. With low input lag I/O ports gamers can feel unparalleled super smooth visuals. Acer monitor shows your movements in real time.
BlueLightShield technology reduces the exposure of blue light, which can be potentially harmful, by adjusting color hue and brightness. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand. Flickerless technology eliminates screen flickering by providing a stable supply of power to the display. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions. ComfyView technology reduces the amount of light being reflected on your display for more comfortable viewing in various settings.
Product Description Acer KG271U - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Adaptive-Sync Technology AMD FreeSync
Features Stereo speakers
Panel Type TN
Aspect Ratio 16:9
Native Resolution 1440p (Quad HD) 2560 x 1440 at 75 Hz
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, 2xDisplayPort
Display Position Adjustments Tilt
Colour Black
Compliant Standards MPR II
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer KG271U 27" 2xHDMI...
£274.16
