The stylish three-pronged stand saves on desk space without sacrificing style. The ZeroFrame design makes for a near-seamless look, allowing you to see more of what matters most: the screen.
Screen tearing will be a thing of the past with AMD FreeSync which syncs your display's frame rate to the video card. A quick response means images refresh quickly, making your gaming sessions seamless and enjoyable.
Product Description | Acer KG281K Abmiipx - LED monitor - 28" | Device Type | LED-backlit LCD monitor - 28" | Energy Class | Class B | Energy Consumption per Year | 58 kWh | Power Consumption (On mode) | 40 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 at 60 Hz | Pixel Pitch | 0.16 mm | Brightness | 330 cd/m² | Response Time | 1 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 65.9 cm x 24.1 cm x 48.2 cm | Weight | 5.49 kg | Compliant Standards | FCC Class B certified, MPR II, UL, TUV GS, VCCI, cUL, RoHS |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 28" |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | 10-bit gamma, ComfyView, Zero Frame, Flicker-Less technology, Low Dimming technology, Acer VisionCare, Acer BluelightShield technology |
Colour | Black |
Dimensions (WxDxH) | 65.9 cm x 24.1 cm x 48.2 cm - with stand |
Weight | 5.49 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DisplayPort , 2 x HDMI , Audio line-out |
Mechanical | |
Tilt Angle | -5/+15 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 34 Watt |
Power Consumption Stand by | 0.37 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 65.9 cm - depth: 24.1 cm - height: 48.2 cm - weight: 5.49 kg , Without stand - width: 65.9 cm - depth: 6.5 cm - height: 38.2 cm - weight: 4.96 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 73.1 cm |
Shipping Depth | 14.7 cm |
Shipping Height | 48.9 cm |
Shipping Weight | 7.83 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
