Acer P1250 XGA 3600 Lumens DLP Projector
£302.54
Delivery:
Standard: 1-3 working days
Key features
  • Rich visuals in XGA resolution
  • 3,600 ANSI lumens for bright, clear images
  • Acer LumiSense content-aware technology & Bluelight Shield
  • Dual HDMI connectivity for HD quality content
  • Environment-friendly lamp life
  • Portability: Portable
  • Stock Status: In Stock
Product codes
See images clearly from a distance with 3,600 lumens of brightness. Even in bright rooms, your presentations will shine as brilliantly as your ideas. The contrast ratio is up to a whopping 20,000:1. DynamicBlack improves image contrast by analyzing onscreen content frame-by-frame and then dynamically adjusting lamp power to optimize black levels. The black can be extremely black and white is brilliant white.
Product Description Acer P1250 - DLP projector - portable - 3D
Device Type DLP projector
3D Capable Yes (3D glasses sold separately)
Built-in Devices Speaker
Brightness 3600 lumens
Contrast Ratio 20000:1 (dynamic)
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Colour Support 1.07 billion colours
Bulb type P-VIP 203 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
Video Input RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V
Power Consumption Operational 260 Watt
Dimensions (WxDxH) 29.95 cm x 22 cm x 10.51 cm
Weight 2.4 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer P1250 XGA 3600 Lu...
£302.54
