Acer P1350W WXGA 3700 Lumens DLP Projector
£405.31
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Crisp text and clear graphics in WXGA resolution
  • 3,700 ANSI lumens for bright, clear images
  • Acer LumiSense content-aware technology & Bluelight Shield
  • Dual HDMI connectivity for HD quality content
  • Environment-friendly lamp life
  • Portability: Portable
  • Stock Status: In Stock
Product codes
See images clearly from a distance with 3,700 lumens of brightness. Even in bright rooms, your presentations will shine as brilliantly as your ideas. The contrast ratio is up to a whopping 20,000:1. DynamicBlack improves image contrast by analyzing onscreen content frame-by-frame and then dynamically adjusting lamp power to optimize black levels. The black can be extremely black and white is brilliant white.
Product Description Acer P1350W - DLP projector - portable - 3D
Device Type DLP projector - 720p
3D Capable Yes (3D glasses sold separately)
Built-in Devices Speaker
Brightness 3700 lumens
Contrast Ratio 20000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type P-VIP 203 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
Video Input RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V
Power Consumption Operational 260 Watt
Dimensions (WxDxH) 29.95 cm x 22 cm x 10.51 cm
Weight 2.4 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer P1350W WXGA 3700...
£405.31
