General |
Device Type |
DLP projector - 1080p |
3D Capable |
Yes (3D glasses sold separately) |
Projector |
Brightness |
3500 ANSI lumens |
Brightness (Reduced) |
2800 ANSI lumens |
Contrast Ratio |
10000:1 (dynamic) |
Image Size |
66 cm - 762 cm |
Throw Ratio |
1.47 - 1.76:1 |
Resolution |
WUXGA - WUXGA (1920 x 1200) |
Native Aspect Ratio |
16:10 |
Max Sync Rate (V x H) |
120 Hz x 100 kHz |
Bulb type |
UHP 203 Watt |
Bulb life cycle |
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode , Up to 15000 hour(s) - extreme economic mode |
Features |
16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, ColorBoost 3D Technology, Acer LumiSense, Acer Bluelight Shield |
Lens |
Focus Type |
Manual |
Lens Aperture |
F/1.94-2.06 |
Zoom Type |
Manual |
Keystone Correction Direction |
Vertical |
Vertical Keystone Correction |
-40 / +40 |
Video Input |
TV System |
PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G |
Video Interfaces |
VGA, HDMI, composite video, MHL |
Video Modes |
480p, 720p, 1080i, 1080p, 480i, 576i, 576p |
Speakers |
Type |
Internal |
Sound Output Mode |
Mono |
Output Power / Channel |
10 Watt |
Speakers |
1 x mixed channel |
Expansion / Connectivity |
Interfaces |
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 (management) |
Miscellaneous |
Included Accessories |
Carrying case, lens cover, wireless remote control, battery for remote control |
Cables Included |
1 x HDMI cable |
Security Features |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Power |
Power Source |
AC |
Nominal Voltage |
AC 100 - 240 V |
Power Consumption Operational |
260 Watt |
Power Consumption Stand by |
0.5 Watt |
Dimensions & Weight |
Width |
34.3 cm |
Depth |
25.8 cm |
Height |
11.4 cm |
Weight |
3.5 kg |
Dimensions & Weight (Shipping) |
Shipping Width |
46 cm |
Shipping Depth |
31.8 cm |
Shipping Height |
18.6 cm |
Shipping Weight |
4.9 kg |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
0 - 80% |
Sound Emission |
30 dBA |
Sound Emission (Economic Mode) |
23 dBA |
