Acer P5330W WXGA 4500 Lumens DLP Projector
£630.07
Delivery:
Key features
  • Bright, clear images
  • Expressive levels of dynamic black contrast
  • Acer LumiSense+ ambient light detection
  • Give color a boost with ColorBoost3D
  • Immune to color decay with Acer ColorSafe II
  • Horizontal & vertical keystone correction
  • Four corner correction
  • Turn up the volume with speaker
  • Portability: Portable
Product codes
High brightness provides the ability to project crystal clear, vibrant images from a long distance on a large screen even in daytime indoors. DynamicBlack improves image contrast by analyzing onscreen content frame-by-frame and then dynamically adjusting lamp power to optimize black levels. The black can be extremely black and white is brilliant white. Project in either light or dark environments with Acer LumiSense+ which adjusts the image based on available light. Equipped with an intelligent ambient light sensor, projector can optimize image brightness and color saturation based on ambient lighting conditions. What's even better, content-aware process also analyzes projected contents frame by frame and dynamically adjusts image visibility to the optimum level.
Acer ColorBoost3D presents true-to-life colors through an optimized 6-segment color-wheel design, advanced lamp illumination technology, and powerful TI image processing. It can reduce brightness decay and color shift while displaying 2D and 3D content through enhancing color brightness, while also compensating color saturation and color temperature. ColorSafe II technology combines the dynamic RGB control techniques, and advanced projector lamps to extend projector lifespan. The technology prevents yellow hues, the sign of color decay, so even after thousands of hours of usage, projector continues to deliver consistent, natural colors.
Image distortion sometimes happens when the projector is placed with improper distance or in a wrong position. Finding the right angle for your presentation will come easier with keystone correction which corrects vertical & horizontal distortions. Adjust distortion from any single corners. Even the projector is not placed in a proper position, the function makes correction process easy and time-saving. Built in speakers provide powerful sound, eliminating the need for external speakers. The audio ensures movies come to life, songs have more depth, and games are more engaging.
Product Description Acer P5330W - DLP projector - portable - 3D - LAN
Device Type DLP projector - 720p
3D Capable Yes (3D glasses sold separately)
Built-in Devices Speaker
Brightness 4500 lumens
Contrast Ratio 20000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type UHP 240 Watt
Bulb life cycle Up to 4000 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
Video Input RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
Video Modes 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V
Power Consumption Operational 290 Watt
Dimensions (WxDxH) 31.5 cm x 21.4 cm x 10.3 cm
Weight 2.73 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer P5330W WXGA 4500...
£630.07
