With projection this crisp and bright, even your most complex concepts will be grasped easily by associates, clients or students. The high resolution and brilliant color of Acer’s Large-Venue Series projectors will let the power of your ideas shine through, and their top-notch technologies will keep you in complete control.
Product Description | Acer P6200S - DLP projector - 3D - LAN | Device Type | DLP projector | 3D Capable | Yes | Built-in Devices | Stereo speakers | Localisation | United Kingdom, Europe | Brightness | 5000 lumens | Contrast Ratio | 20000:1 (dynamic) | Resolution | XGA (1024 x 768) | Native Aspect Ratio | 4:3 | Bulb type | UHP | Bulb life cycle | Up to 3000 hour(s) - normal mode , Up to 4500 hour(s) - economic mode | Video Input | RGB, S-Video, composite video, component video LAN | Speakers | Speaker(s) - integrated | Power | AC 120/230 V | Power Consumption Operational | 383 Watt | Dimensions (WxDxH) | 36.9 cm x 29.4 cm x 11.6 cm | Weight | 4.5 kg |
General | |
3D Capable | Yes |
Projector | |
Image Size | 66 cm - 762 cm |
Projection Distance | 1 m - 8.6 m |
Throw Ratio | 1.4 - 1.91:1 |
Digital Zoom Factor | 2x |
Resolution | XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized) |
Max Sync Rate (V x H) | 120 Hz x 100 kHz |
Bulb type | UHP |
Features | 16:9 aspect ratio support |
Lens | |
Focus Type | Manual |
Lens Aperture | F/2.5-2.93 |
Zoom Type | Manual |
Zoom Factor | 1.4x |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Video Input | |
Analogue video Signal | RGB, S-Video, composite video, component video |
Video Interfaces | VGA, HDMI, component video, composite video, S-Video |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Speakers | |
Type | Integrated |
Sound Output Mode | Stereo |
Output Power / Channel | 10 Watt |
Speakers | 2 x right / left channel |
Expansion / Connectivity | |
Interfaces | 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - mini-DIN , 1 x component video input - RCA x 3 , 3 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x network - RJ-45 |
Miscellaneous | |
Included Accessories | Carrying case, lens cover, wireless remote control |
Cables Included | 1 x component video cable , 1 x composite video cable , 1 x VGA cable |
Power | |
Power Source | AC |
Nominal Voltage | AC 120/230 V |
Dimensions & Weight | |
Width | 36.9 cm |
Depth | 29.4 cm |
Height | 11.6 cm |
Weight | 4.5 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Sound Emission | 33 dB |
Sound Emission (Economic Mode) | 28 dB |
