Vibrant Images
Crisp, true-to-life colors come alive in Full HD 1080p resolution. Movies and games appear more real and dramatic, and small details and text are clear with 1920x1080 resolution in a 16:9 aspect ratio.
Portable and Versatile
Get outstanding portability with an ultra-light, ultraslim PM1 series monitor. At just 790g (with stand detached) and a mere 2cm thin, the 15.6" display slides easily into bags and can accompany you everywhere. It’s ideal for use on the go, takes up minimal desk space, and is perfect for use as a secondary monitor during presentations.
Smooth and blur free: With a 60 Hz refresh rate and 7 ms response time, even high-speed action scenes will look crisp and smooth
Product Description | Acer PM161Q bu - LED monitor - Full HD (1080p) - 15.6" | Device Type | LED-backlit LCD monitor - 15.6" | Energy Class | Class C | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.17925 mm | Brightness | 220 cd/m² | Contrast Ratio | 800:1 / 100000000:1 (dynamic) | Response Time | 7 ms (grey-to-grey) | Colour Support | 262,000 colours | Colour Gamut | 45% NTSC | Input Connectors | USB-C | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 37.7 cm x 2 cm x 23.47 cm | Weight | 970 g |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15.6" |
Panel Type | IPS |
Vertical Refresh Rate | 58 - 62 Hz |
Horizontal Refresh Rate | 30 - 70 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 170 |
Backlight Technology | LED backlight |
Features | Ultra Slim Design, 6-bit gamma, Wide Viewing Angle |
Colour | Black |
Dimensions (WxDxH) | 37.7 cm x 2 cm x 23.47 cm - with stand |
Weight | 970 g |
Connectivity | |
Interfaces | USB-C |
Mechanical | |
Tilt Angle | +15/+35 |
Miscellaneous | |
Cables Included | 1 x USB-C cable , 1 x micro-USB cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 7 kWh/1000h |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 37.7 cm - depth: 2 cm - height: 23.47 cm - weight: 970 g , Without stand - width: 37.7 cm - depth: 2 cm - height: 23.47 cm - weight: 790 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
