Marketing description is not available.
Product Description | Predator XB252Q - 3D LED monitor - Full HD (1080p) - 24.5" | Device Type | LED-backlit LCD monitor - 24.5" | Energy Class | Class A | Energy Consumption per Year | 38 kWh | Power Consumption (On mode) | 26 W | 3D Capable | Yes | Adaptive-Sync Technology | NVIDIA G-SYNC | Features | USB 3.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 240 Hz | Brightness | 400 cd/m² | Contrast Ratio | 1000:1 | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black, dark silver | Dimensions (WxDxH) | 55.789 cm x 26.831 cm x 50.587 cm | Weight | 3.1 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24.5" |
3D Capable | Yes |
3D Technology | Active |
Built-in Devices | USB 3.0 hub |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | ErgoStand, Zero Frame, nVidia 3D Vision, NVIDIA Ultra Low Motion Blur Technology, Acer VisionCare |
Weight | 3.1 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DisplayPort , USB 3.0 upstream (Type B) , HDMI , 4 x USB 3.0 downstream (Type A) |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 115 mm |
VESA Mounting Interface | 100 x 100 mm |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 23 Watt |
Power Consumption Sleep | 0.46 Watt |
Power Consumption (Off Mode) | 0.43 Watt |
