We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Acer's ProDesigner PE320QK monitor features ultra-high-definition 4K resolution (3840 x 2160 pixels) for displaying high-quality images in amazing detail. Photographers, video editors and others working in creative industries will appreciate the monitor's HDR Xpert technology, which enhances brightness for a vivid contrast between lights and darks, while covering a wider gamut for truly vibrant colors. The monitor's sleek ZeroFrame designs virtually eliminate the screen bezel for a seamless visual experience, with an added style benefit by adding a touch of modernity to the office. It includes a reversible USB-C port for easily connecting and charging devices to reduce desktop clutter, supporting power delivery of up to 85W. The ProDesigner PE320QK monitor produces accurate colors with a low Delta E < 1, supporting 130% of the sRGB and 95% of the DCI-P3 color gamut. The monitor also sports Acer VisionCare technology to reduce eye strain and fatigue during long editing sessions.
Product Description | Acer ProDesigner PE320QK - LED monitor - 31.5" - HDR | Device Type | LED-backlit LCD monitor - 31.5" | Energy Class | Class B | Energy Consumption per Year | 69 kWh | Power Consumption (On mode) | 47 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 at 60 Hz | Pixel Pitch | 0.182 mm | Brightness | 350 cd/m² | Contrast Ratio | 1300:1 / 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 95.7% DCI-P3, 99.8% sRGB | Input Connectors | 2xHDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100/240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - without stand | 74.67 cm x 17.9 cm x 41.5 cm | Weight | 8.08 kg | Localisation | Romania, Spain | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | VCCI, CCC, FCC, DDC/CI, RoHS, ISO 9241-307, EAC, TUV Rheinland, NOM-NYCE | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 31.5" |
Built-in Devices | USB 3.1 hub |
Panel Type | IPS |
Pixel Per Inch | 139.9 |
Vertical Refresh Rate | 23 - 86 Hz |
Horizontal Refresh Rate | 30 - 160 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, 6-axis Hue, 6-axis Saturate, Acer HDR Xpert technology, AcuMotion technology, Acer Enhanced Color Accuracy |
Colour | Black |
Dimensions (WxDxH) | 74.67 cm x 17.9 cm x 41.5 cm - without stand |
Weight | 8.08 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 4 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , 4 x USB 3.1 downstream , USB 3.1 upstream , Audio line-out |
Mechanical | |
Tilt Angle | -5/+20 |
Rotation Angle | 180 |
Height Adjustment | 115 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support, Acer ColorPlus technology |
Cables Included | 1 x USB-C cable , 1 x DisplayPort cable , 1 x VGA cable |
Power | |
Input Voltage | AC 100/240 V (50/60 Hz) |
Power Consumption Stand by | 500 mW |
Power Consumption (Off Mode) | 400 mW |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - weight: 11 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 85% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
