Wash away thick borders and enter a world of ZeroFrame design. A world that is seamless, ultrathin and styled in finesse. Rich, vivid colors spring forth in 2560x1440 resolution on the IPS display of the RC1 monitor.
Acer RC271U - LED monitor - 27"
LED-backlit LCD monitor - 27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Black, silver
61.5 cm x 20.1 cm x 44.5 cm
3.81 kg
France
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Zero Frame
Black, silver
61.5 cm x 20.1 cm x 44.5 cm - with stand
3.81 kg
DVI , HDMI , DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
VESA interface support
1 x DVI cable , 1 x DisplayPort cable
MPR II
France
AC 100/240 V (50/60 Hz)
27 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 20.1 cm - height: 44.5 cm - weight: 3.81 kg , Without stand - width: 61.4 cm - depth: 3.7 cm - height: 36.4 cm - weight: 3.4 kg
ENERGY STAR Certified
Customer reviews
