Acer RC271U 27" 2560x1440 4ms DVI HDMI DP LED Monitor
Key features
  • At a mere 7 mm thickness, you might miss the RC1 monitor at first glance but will have a hard time looking away
  • The ZeroFrame design makes for a near-seamless look, allowing you to see more of what matters most: the screen
  • A diamond-cut C-shaped metal stand with a firm transparent neck holds the RC1 aloft, allowing a tilt of -5° to 15°
  • A pair of built-in 2W speakers make sitting back and relaxing with your favorite media that much easier
  • The RC1 is a 16:9 (2560x1440) WQHD monitor - the screen is wide, the images are sharp and the view is perfect
  • The RC1 monitor features an IPS panel, allowing colors to be presented accurately with a viewing angle of up to 178°
Product codes
Wash away thick borders and enter a world of ZeroFrame design. A world that is seamless, ultrathin and styled in finesse. Rich, vivid colors spring forth in 2560x1440 resolution on the IPS display of the RC1 monitor.
Product Description Acer RC271U - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 39 kWh
Power Consumption (On mode) 27 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440 at 60 Hz
Brightness 350 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 4 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, DisplayPort
Display Position Adjustments Tilt
Colour Black, silver
Dimensions (WxDxH) - with stand 61.5 cm x 20.1 cm x 44.5 cm
Weight 3.81 kg
Localisation France
Environmental Standards ENERGY STAR Qualified
Compliant Standards MPR II
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
