Acer RT280Kbmjdpx 28" 3840x2160 1ms DVI HDMI DP Monitor
£365.47
Delivery:
Key features
  • Quality visuals
  • Slender KeySellingPoints, sleek stand
  • Good for your eyes
Product codes
These displays deliver high resolution, for vivid images that look clear from any angle. You also get multiple display connectors to make it easy to connect any video source. RT0 monitors feature very thin panels. Its ZeroFrame design means the bezels around the sides of the screen are also very thin, to minimize visual clutter. The slender screen is perfectly balanced by the sleek T-shaped stand. RT0 displays use Flicker-less technology to reduce eye-strain-causing screen flickering. Blue Light Filter technology lets you filter out strain-causing blue light when you have to work long hours, and Acer ComfyView technology reduces the light reflected off the screen.
Acer RT280K - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Environmental Standards
ENERGY STAR Qualified
MPR II
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer RT280Kbmjdpx 28"...
£365.47
